Api session event editor excelsheet remove
Revision as of 14:44, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorexcelsheet/remove/
Description: Remove existing Excel Sheet
0 REQUIRED (EXCEL_SHEET Integer ID or multiple values in array [1, 2, 3]) Excel Sheets
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/remove/", options)
