Api session event editor cinematic move keypoint
API Endpoint: api/session/event/editorcinematic/move_keypoint/
Description: Move KeyPoint
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Datas | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (Integer number) | Integer |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/move_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'JavaScript example POST:
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/move_keypoint/", options)
