Api session event editor cinematic duplicate keypoint
Revision as of 14:44, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorcinematic/duplicate_keypoint/
Description: Duplicate KeyPoint
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Datas
1 REQUIRED (Integer number) Integer
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorcinematic/duplicate_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/duplicate_keypoint/", options)
