Api session event editor area generate water areas
Revision as of 14:44, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/generate_water_areas/
Description: Generate Water Areas
0 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '79'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '57'
JavaScript example POST:
 body: '79'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
