Api session event editor address search
Revision as of 14:44, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoraddress/search/
Description: Search Addresses
0 REQUIRED (String) Search Query
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editoraddress/search/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Search Query"'
JavaScript example POST:
 body: '"Search Query"'
fetch("https://engine.tygron.com/api/session/event/editoraddress/search/", options)
