Api session event editor clear map
Revision as of 14:43, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/clear_map/
Description: Remove all geospatial data of the Project, such as Buildings, Areas, etc.
0 REQUIRED (true, false) Delete the map size and georeference too (false means deleting only the geodata) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editor/clear_map/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript example POST:
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editor/clear_map/", options)
