Api session event logic net clusters set state
API Endpoint: api/session/event/logic/net_clusters_set_state/
Description: Per Net Cluster, set all its Net Load of the provided Net Type to the given Timestate.
0 REQUIRED (NET_CLUSTER Integer ID or multiple values in array [1, 2, 3]) Net Cluster IDs
1 REQUIRED (NetType or multiple values in array [a, b, c]) Net Type of loads to be changed.
2 REQUIRED (TimeState or multiple values in array [a, b, c]) Timestate (NOTHING, REQUEST_CONSTRUCTION_APPROVAL, REQUEST_ZONING_APPROVAL, READY)
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_clusters_set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ELECTRICITY", "NOTHING" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_clusters_set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'
JavaScript example POST:
 body: '[ 1, "ELECTRICITY", "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_clusters_set_state/", options)
