Api session event participant net cluster set state
API Endpoint: api/session/event/participant/net_cluster_set_state/
Description: Set TimeState for all Net Load of Net Cluster.
0 REQUIRED (STAKEHOLDER Integer ID) Initiating Stakeholder ID
1 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
2 REQUIRED (Enumeration) Timestate (NOTHING, REQUEST_CONSTRUCTION_APPROVAL, REQUEST_ZONING_APPROVAL, READY) CONSTRUCTING, CONSTRUCTION_APPROVED, CONSTRUCTION_DENIED, DEMOLISH_APPROVED, DEMOLISH_DENIED, DEMOLISH_FINISHED, DEMOLISHING, NOTHING, PENDING_CONSTRUCTION, PENDING_DEMOLISHING, PENDING_UPGRADE, READY, REQUEST_CONSTRUCTION_APPROVAL, REQUEST_DEMOLISH_APPROVAL, REQUEST_DEMOLISH_ZONING_APPROVAL, REQUEST_PLOT_OWNER_APPROVAL, REQUEST_ZONING_APPROVAL, WAITING_FOR_DATE or WAITING_FOR_DEMOLISH_DATE
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "NOTHING" ]'
JavaScript example POST:
 body: '[ 1, 1, "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_state/", options)
