Api session event participant stakeholder set location
Revision as of 09:26, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/participant/stakeholder_set_location/ Description: Set the location of a Stakeholder in the 3D world. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(Point with crs: EPSG:3857) |Location of the Stakeholder on the map as Point | |- |2 |REQUIRED |(true, false) |Ping others (show them my location) |true or false |}...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (Point with crs: EPSG:3857) Location of the Stakeholder on the map as Point
2 REQUIRED (true, false) Ping others (show them my location) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658781.5438394813, 6799425.6409475235 ]
}, true ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658725.3990788531, 6799457.691569096 ]
}, true ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658781.5438394813, 6799425.6409475235 ]}, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857", options)
