Api session event participant net cluster set states
API Endpoint: api/session/event/participant/net_cluster_set_states/
Description: Set TimeState for all Net Load of Net Cluster.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Initiating Stakeholder ID | |
| 1 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster ID | |
| 2 | REQUIRED | (NetType or multiple values in array [a, b, c]) | Net Type Array | |
| 3 | REQUIRED | (TimeState or multiple values in array [a, b, c]) | Time State Array (NOTHING, REQUEST_CONSTRUCTION_APPROVAL, REQUEST_ZONING_APPROVAL, READY) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "ELECTRICITY", "NOTHING" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'JavaScript example POST:
body: '[ 1, 1, "ELECTRICITY", "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/", options)
