Api session event participant net cluster set load attribute
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/participant/net_cluster_set_load_attribute/ Description: For each Net Load of a Net Cluster, set the value of the attribute. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Initiating Stakeholder ID | |- |1 |REQUIRED |(NET_CLUSTER Integer ID) |Net Cluster ID | |- |2 |REQUIRED |(String) |Attribute name | |- |3 |REQUIRED |(Floating point number) |Value | |} ===Respon...")
0 REQUIRED (STAKEHOLDER Integer ID) Initiating Stakeholder ID
1 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
2 REQUIRED (String) Attribute name
3 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name", 52 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name", 27 ]'
JavaScript example POST:
 body: '[ 1, 1, "Attribute name", 52 ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/", options)
