Api session event participant event bundle apply server events
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/participant/event_bundle_apply_server_events/ Description: Apply a bundle of events on the serverside for a particular Stakeholder. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(EVENT_BUNDLE Integer ID) |Event Bundle ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Action Log ID) |- |300-...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle ID
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/event_bundle_apply_server_events/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/event_bundle_apply_server_events/", options)
