Api session event participant building plan demolish polygon
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/participant/building_plan_demolish_polygon/ Description: Plan the demolition of a Building in the given polygon in the MAQUETTE map. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(MultiPolygon with crs: EPSG:3857) |Multipolygon describing the demolition Area | |- |2 |REQUIRED |(Enumeration) |Ground type: SURFACE or UNDERGROUND |BRIDG...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (MultiPolygon with crs: EPSG:3857) Multipolygon describing the demolition Area
2 REQUIRED (Enumeration) Ground type: SURFACE or UNDERGROUND BRIDGE, SURFACE or UNDERGROUND
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/building_plan_demolish_polygon/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "BRIDGE" ]
JavaScript example POST:
 body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, "BRIDGE" ]'
fetch("https://engine.tygron.com/api/session/event/participant/building_plan_demolish_polygon/?crs=3857", options)
