Api session event participant building plan demolish
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/participant/building_plan_demolish/ Description: Plan the demolition of a Building in the MAQUETTE map. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID (also owner) | |- |1 |REQUIRED |(BUILDING Integer ID) |Building ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Action Log ID) |- |300-600 |Codes Overview |}...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID (also owner)
1 REQUIRED (BUILDING Integer ID) Building ID
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/building_plan_demolish/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/building_plan_demolish/", options)
