Api session event logic stakeholder select
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/stakeholder_select/ Description: Select Stakeholder with preferred ID, when not available fallback to next best. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(Integer number) |Preferred Stakeholder ID or empty | |- |1 |REQUIRED |(String) |Client Token (from Join Session event) | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Selected Stakeholde...")
0 REQUIRED (Integer number) Preferred Stakeholder ID or empty
1 REQUIRED (String) Client Token (from Join Session event)
200 Integer (Selected Stakeholder ID)
curl 'https://engine.tygron.com/api/session/event/logic/stakeholder_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Client Token" ]'
JavaScript example POST:
 body: '[ 1, "Client Token" ]'
fetch("https://engine.tygron.com/api/session/event/logic/stakeholder_select/", options)
