Api session event logic net lines set attribute
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/net_lines_set_attribute/ Description: For each Net Line, set the value of the attribute. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_LINE Integer ID or multiple values in array [1, 2, 3]) |Array of Net Line IDs | |- |1 |REQUIRED |(String) |Attribute | |- |2 |REQUIRED |(Floating point number) |Value | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No C...")
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Array of Net Line IDs
1 REQUIRED (String) Attribute
2 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 67 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute", 47 ]'
JavaScript example POST:
 body: '[ 1, "Attribute", 67 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/", options)
