Scenario
What are Levels?
A Level is a relative position or rank on a scale.
How do Levels relate to the Tygron Engine
  • to provide the session participants a learning curve, to get used to interacting with the Tygron Engine
Create a first level as tutorial where a stakeholder can only perform a limited number of actions and measures. This can even happen in a secluded area of the 3D World, to get acquainted with the interaction with the Tygron Engine, without affecting the outcome of the session as a whole.
  • to gradually make the project interaction more complex, to match the issue in real life more closely
Add more complex actions, measures and indicators to let session participants gradually experience the complexity of the spatial planning issue(s) at hand.
  • to jump in time to a future scenario
Each level can start with an event or measure that reflects future scenarios, such as floodings that only occur once every fifty and every one hundred years, or the sea level rising over time.
  • to provide pause moments during a session
Sessions often take up a whole morning, afternoon or even the whole day. By implementing levels the session flow can be interrupted to incorporate pause moments for reflection and refreshments.
Adding, duplicating and removing Levels in a project
Template:Editor ribbon
Adding a Level
Add new level - drop down menu
Add new level - left panel
How to add levels to a project:
  1. Select Storyline → Levels
  2. Select Add new Level from the drop down menu
  3. Or select Add on the bottom of the left panel
Duplicating a Level
Select level to duplicate on left panel
Duplicate selected level - left panel
How to duplicate levels in a project:
  2. Select the level to be duplicated on the left panel
  3. Select Duplicate on the bottom of the left panel
Removing a Level from a project
Select level to remove on left panel
Remove selected level - left panel
How to remove levels in a project:
  2. Select the level to be removed on the left panel
  3. Select Remove on the bottom of the left panel
Changing the properties of a Level
Level
Levels Left Panel
Name
Main article: Names
Enter the level name here - right panel
In the Name field a more suitable name can be entered, if desired. Examples of this can be: "Tutorial", "Prologue", etc.
How to change the name of a level:
  2. Select Level to be renamed from the left panel
  3. Select Name field on right panel
  4. Delete the previous name
  5. Enter new name
  6. Confirm by pressing the 'Enter' key
Description
Describe the level - right panel
The description field allows for describing the level in the Editor. This is convenient when the level has added complexity. The description will appear on the Level panel of the Admin Interface, providing a short summary of the levels in the project.
How to change the description of a level:
  2. Select Level to have description added from the left panel
  3. Select Description field on right panel
  4. Delete the previous text (if needed)
  5. Enter new description
  6. Text is instantly confirmed when typed ('Enter' key adds hard return to text)
Event Bundles
Add events to a level
Main article: Events
An event is something that occurs, on which the application can react. By selecting the Event Bundles option of a level, (a bundle of) Server events can be added to a level, that will trigger as soon as the level starts.
Server Events fired when chosen
This section manages Server Events that are fired when the level is 'chosen' (= when level is started). Events can be assigned on the right panel to the selected level, after being added with the 'Add Event' button on the bottom of the right panel. Then the desired event can be selected from a list on the bottom panel. The selection can be confirmed with the 'Commit' button, or cancelled with the 'Cancel' button.
How to add events to a level:
  2. Select Level to have events added to
  3. Select Event Bundles from the selected level
  4. Select 'Add event' on the bottom of the right panel
  5. Select the newly added event on the right panel
  6. Select the desired server event from the bottom panel
  7. Confirm the selection with the 'Commit' button, or use the 'Cancel' button to clear the selection
Event bundle Bottom Panel with 'Commit' and 'Cancel' buttons
Measures
Main article: Measures
Assign measures
Besides events it is also possible to trigger measures (=predefined actions) at the start of a new level. For example; in the first level the stakeholders looked into different spatial alignments of possible solutions, in the second level, one alignment is constructed at the start of the level as such an automated measure, to accommodate further discussions. Prerequisite for this is to have the measure(s) already available, then select the Measures entry on the left panel. The available measures will then show up on the right panel, which can then be assigned to the selected level.
How to add measures to a level:
  1. Ensure predefined measures are available in the project
  2. Select Storyline → Levels
  3. Select the level to have measures added to
  4. Select on the left panel the Measures property from the selected level
  5. Mark the check box of the desired measure from the available entries on the right panel
Stakeholders
Stakeholder properties (right panel)
Main article: Stakeholders
Selecting the arrow next to 'Stakeholders' on the left panel opens up the stakeholder section, containing the names of all active stakeholders in the project. Here the stakeholder properties can be set up per level. The following properties can be adjusted:
Provided Budget
Main article: Budget (Indicator)
The Provided Budget is the budget increment that happens at the start of the level. This can be the fixed income per stakeholder per period, or a dedicated subsidy flow for a special cause for example. This increment is separate from any income generated during the level from stakeholder actions.
How to change the incremental level budget for a stakeholder:
  2. Select the level to have the stakeholder budget changed from
  3. Select on the left panel the Stakeholder from the Stakeholder list of the selected level
  4. Enter a new budget in the budget field on the right panel
  5. Confirm by using the 'Enter' key
Start with Cinematic
Main article: Cinematics
To introduce the new level with a cinematic, each stakeholder can have a tailor made cinematic triggered at the start of each level to inform about the intricacies of the new level at hand. These cinematics must be created first, before they are available for selection from the drop down menu on the right panel.
How to change the level stating cinematic a stakeholder:
  1. Ensure a proper cinematic is available
  3. Select the level to have the stakeholder cinematic changed from
  4. Select on the left panel the affected Stakeholder from the Stakeholder list of the selected level
  5. Select on the right panel the desired cinematic from the drop down menu
  6. Mark the check box 'Start with Cinematic' to activate the cinematic at the start of the level
Active Action Menus
Main article: Actions
It is possible to assign more (or even different) action menus for each consecutive level, for each stakeholder. This is very useful when levels are implemented to build up complexity over the course of a session. Available action menus are present in a list with check boxes. Checking a box adds the action menu to the selected stakeholder for that level.
How to change the available actions for a stakeholder in the selected level:
  2. Select the level to have the stakeholder actions changed from
  3. Select on the left panel the affected Stakeholder from the Stakeholder list of the selected level
  4. Mark on the right panel the check boxes of the desired action menus
Playable Zones
Main article: Zones
Select which zones are active
This section allows for assigning dedicated areas in the 3D world to the selected level. Any non selected area is not playable, which means that any planned action here will not be deployable; the Action brush selection will color red to visualize this. This allows, as example, for the first tutorial level to take place in a small corner of the 3D world that does not have a large impact on the overall progression of the session.
How to change playable zones of a level:
  2. Select the level to change on the left panel
  4. Mark on the right panel the check boxes the playable zones to be active at the start of the level
