Api session event logic measurement point add
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/measurement_point_add/ Description: Add a PointMeasurement for an Overlay. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID or multiple values in array [1, 2, 3]) |Overlay IDs | |- |1 |REQUIRED |(Point with crs: EPSG:3857) |Point | |- |2 |REQUIRED |(String) |Name | |- |3 |REQUIRED |(true, false) |Save Measurement |true or...")
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs
1 REQUIRED (Point with crs: EPSG:3857) Point
2 REQUIRED (String) Name
3 REQUIRED (true, false) Save Measurement true or false
4 REQUIRED (true, false) Sum true or false
200 Integer (Measurement ID)
curl 'https://engine.tygron.com/api/session/event/logic/measurement_point_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658786.0962929523, 6799334.324819751 ]
}, "Name", true, true ]
Curl example multi item POST:
[ [ 1, 2, 3 ], {
 "type" : "Point",
 "coordinates" : [ 658795.9320611367, 6799433.327952874 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658786.0962929523, 6799334.324819751 ]}, "Name", true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_point_add/?crs=3857", options)
