Api session event logic measurement line add
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/measurement_line_add/ Description: Add a LineMeasurement for an Overlay for a specific Timeframe. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID or multiple values in array [1, 2, 3]) |Overlay IDs | |- |1 |REQUIRED |(Point with crs: EPSG:3857) |Point start | |- |2 |REQUIRED |(Point with crs: EPSG:3857) |Point end | |- |3 |...")
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs
1 REQUIRED (Point with crs: EPSG:3857) Point start
2 REQUIRED (Point with crs: EPSG:3857) Point end
3 REQUIRED (String) Name
4 REQUIRED (Integer number) Timeframe (-1 for automatic last)
5 REQUIRED (true, false) Save Measurement true or false
6 REQUIRED (true, false) Sum true or false
200 Integer (Measurement ID)
curl 'https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658652.5127233695, 6799372.5710882 ]
 "type" : "Point",
 "coordinates" : [ 658780.9705194401, 6799415.0467621675 ]
}, "Name", -1, true, true ]
Curl example multi item POST:
[ [ 1, 2, 3 ], {
 "type" : "Point",
 "coordinates" : [ 658664.4306340262, 6799438.76067076 ]
 "type" : "Point",
 "coordinates" : [ 658797.1550356153, 6799458.576722857 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658652.5127233695, 6799372.5710882 ]}, { "type" : "Point", "coordinates" : [ 658780.9705194401, 6799415.0467621675 ]}, "Name", -1, true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857", options)
