Api session event logic cinematic stakeholder stop
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/cinematic_stakeholder_stop/ Description: Stop any Cinematic for a specific Stakeholder. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Curl example POST: <syntaxhighlight lang="text" copy>curl 'https://eng...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_stop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_stop/", options)
