Api session event logic areas set attributes
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/areas_set_attributes/ Description: Per entry in the array, set the value of the attribute for the Area. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(AREA Integer ID or multiple values in array [1, 2, 3]) |Array of Area IDs | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Array of Attributes | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0,...")
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Array of Area IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Array of Attributes
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Array of Values
3 OPTIONAL (true, false) Update Indicator (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/areas_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Array of Attribute 1", 1.0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/areas_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Array of Attribute 1", "Array of Attribute 2", "Array of Attribute 3" ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST:
 body: '[ 1, "Array of Attribute 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/areas_set_attributes/", options)
