Api session event logic area set attribute
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/area_set_attribute/ Description: Set Area Attribute to given number Value. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(AREA Integer ID or multiple values in array [1, 2, 3]) |Area ID | |- |1 |REQUIRED |(String) |Attribute Name | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |Value | |- |3 |OPTIONAL |(true, false) |Update Indicator (optional) | |...")
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Area ID
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value
3 OPTIONAL (true, false) Update Indicator (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/area_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/area_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST:
fetch("https://engine.tygron.com/api/session/event/logic/area_set_attribute/", options)
