Api session event editor netnode set location
API Endpoint: api/session/event/editornetnode/set_location/
Description: Set Location
| 0 | REQUIRED | (Enumeration) | Network type | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (NET_NODE Integer ID) | Net Node ID | |
| 2 | REQUIRED | (Point 3D with crs: EPSG:3857) | Location Point | |
| 3 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetnode/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", 1, {
"type" : "Point",
"coordinates" : [ 658663.6461762928, 6799318.783721327, -1.95 ]
'Curl example multi item POST:
"type" : "Point",
"coordinates" : [ 658798.1311414078, 6799429.387813576, -0.03 ]
'JavaScript example POST:
body: '[ "ELECTRICITY", 1, { "type" : "Point", "coordinates" : [ 658663.6461762928, 6799318.783721327, -1.95 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetnode/set_location/?crs=3857", options)
