Api session event editor measure import upgrades
API Endpoint: api/session/event/editormeasure/import_upgrades/
Description: Import Measure Upgrade Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of Upgrade Geometries | |
| 1 | REQUIRED | (UPGRADE_TYPE Integer ID or multiple values in array [1, 2, 3]) | Upgrade Type | |
| 2 | OPTIONAL | (MEASURE Integer ID) | Set for existing Measure ID (optional) | |
| 3 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 4 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
| 200 | Integer (Measure ID) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_upgrades/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1 ]
'Curl example multi item POST:
"geometries" : [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ 1, 2, 3 ] ]
'JavaScript example POST:
body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_upgrades/?crs=3857", options)
