Api session items terrains
Api session items Terrain Endpoints.
Default Query:
https://engine.tygron.com/api/session/items/terrains/?f=JSON&token=API_TOKEN
Example Response:
  "current" : {
    "type" : "MultiPolygon",
    "coordinates" : [ [ [ [ 657093.832562376, 6800274.005242179 ], [ 657093.832562376, 6799664.916014099 ], [ 658068.3142186847, 6799664.916014099 ], [ 658068.3142186847, 6800274.005242179 ], [ 657093.832562376, 6800274.005242179 ] ] ] ]
  "heightValuesCurrent" : null,
  "heightValuesMaquette" : null,
  "id" : 0,
  "maquette" : null,
  "name" : "1",
  "showSatellite" : true,
  "sourceIDs" : [ ],
  "typeID" : 9,
  "version" : 6
  "current" : {
    "coordinates" : [ [ [ [ 658068.3142186847, 6800274.005242179 ], [ 658068.3142186847, 6799664.916014099 ], [ 659042.7958749932, 6799664.916014099 ], [ 659042.7958749932, 6800274.005242179 ], [ 658068.3142186847, 6800274.005242179 ] ] ] ]
  "id" : 2,
  "maquette" : null,
  "name" : "3",
  "sourceIDs" : [ ],
  "typeID" : 9,
  "version" : 15
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/terrains/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/terrains/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/terrains/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/terrains/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/terrains/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/terrains/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/terrains-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/terrains/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/terrains/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/terrains/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/terrains/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/terrains/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/terrains/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/terrains/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/terrains/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/terrains/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/terrains/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/terrains/?f=ZIPSMILE&token=API_TOKEN
Api Model EmptyMultiPolygon
API Model description of EmptyMultiPolygon
Name Type Description
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of polygons; polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Terrain
API Model description of Terrain
current MultiPolygon
heightValuesCurrent double[]
heightValuesMaquette double[]
id int
maquette MultiPolygon
name String
showSatellite boolean
sourceIDs int[] Source ID
typeID int Terrain Type ID
version int
