Api session event editor area generate water areas
API Endpoint: api/session/event/editorarea/generate_water_areas/
Description: Generate Water Area
0 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '27'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '67'
JavaScript example POST:
 body: '27'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
