Api session event editor scenario remove measure
API Endpoint: api/session/event/editorscenario/remove_measure/
Description: Remove Measure
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario | |
| 1 | REQUIRED | (MEASURE Integer ID) | Measure |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorscenario/remove_measure/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/remove_measure/", options)
