Api session event editor scenario set active
API Endpoint: api/session/event/editorscenario/set_active/
Description: Activate Scenario, when testrun is active the Scenerio can restart it.
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_active/", options)
