Api session event editor panel set layout xy
API Endpoint: api/session/event/editorpanel/set_layout_xy/
Description: Set Layout Xy
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Floating point number) | Double | |
| 2 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 3, 58 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 51, 64 ]'JavaScript example POST:
body: '[ 1, 3, 58 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/", options)
