Api session event editor panel remove answer event
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/remove_answer_event/
Description: Remove Answer (Panel) Event
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
3 REQUIRED (Integer number) Integer
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false, 1 ]'
JavaScript example POST:
 body: '[ 1, 1, true, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/", options)
