Api session event editor panel add template
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/add_template/
Description: Add Template
0 REQUIRED (Enumeration) PanelTemplate DANGEROUS_OBJECTS, NETWORK_INTERACTION, TRAFFIC_NOISE, WATER_AREAS or WEIRS
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_template/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TRAFFIC_NOISE"'
JavaScript example POST:
 body: '"TRAFFIC_NOISE"'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_template/", options)
