Api session event editor overlay set water mode
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_water_mode/
Description: Set Water Mode
0 REQUIRED (OVERLAY Integer ID) Overlay
1 REQUIRED (Enumeration) Mode ACCURACY, AVERAGE or SPEED
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SPEED" ]'
JavaScript example POST:
 body: '[ 1, "SPEED" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/", options)
