Api session event editor overlay set avg distance
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_avg_distance/
Description: Set the averaging distance for a specified AVG Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an AVG Overlay)
1 REQUIRED (Floating point number) Averaging distance
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 42 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 38 ]'
JavaScript example POST:
 body: '[ 1, 42 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/", options)
