Api session event editor netnode set location
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetnode/set_location/
Description: Set Location
0 REQUIRED (Enumeration) Network type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (NET_NODE Integer ID) Net Node ID
2 REQUIRED (Point 3D with crs: EPSG:3857) Location Point
3 OPTIONAL (Floating point number) Node merge distance (optional, default: 1.0m)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetnode/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", 1, {
 "type" : "Point",
 "coordinates" : [ 658778.7129702697, 6799446.350240589, -0.06 ]
}, 1.0 ]
Curl example multi item POST:
 "type" : "Point",
 "coordinates" : [ 658771.8380021844, 6799371.768773865, -0.09 ]
}, 1.0 ]
JavaScript example POST:
 body: '[ "ELECTRICITY", 1, { "type" : "Point", "coordinates" : [ 658778.7129702697, 6799446.350240589, -0.06 ]}, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editornetnode/set_location/?crs=3857", options)
