Api session event editor netload generate loads
API Endpoint: api/session/event/editornetload/generate_loads/
Description: Generate Loads
| 0 | REQUIRED | (Enumeration) | Net Type | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon | |
| 2 | REQUIRED | (Category or multiple values in array [a, b, c]) | Category[] | |
| 3 | REQUIRED | (Integer number) | Integer | |
| 4 | REQUIRED | (Integer number) | Integer | |
| 5 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Stakeholder | |
| 6 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Stakeholder | |
| 7 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_loads/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "SOCIAL", 1, 1, 1, 1, true ]
'Curl example multi item POST:
[ "ELECTRICITY", {
}, [ "SOCIAL", "NORMAL", "LUXE" ], 1, 1, [ 1, 2, 3 ], [ 1, 2, 3 ], false ]
'JavaScript example POST:
body: '[ "ELECTRICITY", { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, "SOCIAL", 1, 1, 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_loads/?crs=3857", options)
