Api session event editor levee set angle degrees
API Endpoint: api/session/event/editorlevee/set_angle_degrees/
Description: Set Angle Degrees
| 0 | REQUIRED | (LEVEE Integer ID) | Levee | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 84 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 32 ]'JavaScript example POST:
body: '[ 1, 84 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/", options)
