Api session event editor global set point
Revision as of 08:15, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorglobal/set_point/
Description: Set Point
0 REQUIRED (GLOBAL Integer ID) Global
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658721.6976726952, 6799426.425401782 ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658757.8444455998, 6799358.439648332 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658721.6976726952, 6799426.425401782 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857", options)
