Api session event editor global remove book value
API Endpoint: api/session/event/editorglobal/remove_book_value/
Description: Remove Book Value
| 0 | REQUIRED | (GLOBAL Integer ID) | Global |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorglobal/remove_book_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorglobal/remove_book_value/", options)
