Api session event editor global add query
API Endpoint: api/session/event/editorglobal/add_query/
Description: Add Query
| 0 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorglobal/add_query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'JavaScript example POST:
body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorglobal/add_query/", options)
