Api session event editor building reset slanting roof height
Revision as of 08:14, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/reset_slanting_roof_height/
Description: Reset Height of the Slanting Roof of a Building section
0 REQUIRED (BUILDING Integer ID) Building ID
1 REQUIRED (Integer number) Section ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/reset_slanting_roof_height/", options)
