Api session event editor area generate water areas
Revision as of 08:14, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/generate_water_areas/
Description: Generate Water Area
0 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '18'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '76'
JavaScript example POST:
 body: '18'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
