Api session event editor area add group
Revision as of 08:14, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/add_group/
Description: Add Group
0 REQUIRED (String) Attribute name to group Area by
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/add_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Attribute name to group Areas by"'
JavaScript example POST:
 body: '"Attribute name to group Areas by"'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_group/", options)
