Api session event editor area set attributes
API Endpoint: api/session/event/editorarea/set_attributes/
Description: Set multiple Area attribute values
| 0 | REQUIRED | (AREA Integer ID or multiple values in array [1, 2, 3]) | Area | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1", [ 1.0, 2.0 ], "" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], "" ]'JavaScript example POST:
body: '[ 1, "Attribute Name 1", [ 1.0, 2.0 ], "" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/set_attributes/", options)
