Api session event editor clear map
Revision as of 08:12, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/clear_map/
Description: Remove all geospatial data of the Project, such as Building, Area, etc.
0 REQUIRED (true, false) Delete the map size and georeference too (false means deleting only the geodata) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editor/clear_map/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'
JavaScript example POST:
 body: 'false'
fetch("https://engine.tygron.com/api/session/event/editor/clear_map/", options)
