Api session items parametricdesigns
Revision as of 14:14, 24 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Parametric Designs Endpoints.
Edit items with event: editorparametric.
Default Query:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/parametricdesigns/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/parametricdesigns/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/parametricdesigns/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPSMILE&token=API_TOKEN
Api Model Alignment
API Enumeration description of Alignment
Name Description
ROAD
SPACED
Api Model EmptyMultiPolygon
API Model description of EmptyMultiPolygon
Name Type Description
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
Api Model ParametricDesign
API Model description of ParametricDesign
alignment Alignment
attributes Map<String,double[]>
center Point
gardenID int Function ID
id int
maquetteOverride Map<String,double[]>
name String
parkingID int Function ID
plotDesigns PlotDesign[]
polygons MultiPolygon
publicGreenID int Function ID
roadID int Function ID
sidewalkID int Function ID
sourceIDs int[] Source ID
version int
waterID int Terrain Type ID
Api Model PlotDesign
API Model description of PlotDesign
functionID int Function ID
id int
multiPolygon MultiPolygon
Api Model Point
API Model description of Point
