Api session items globals
Revision as of 14:13, 24 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Global Endpoints.
Edit items with event: editorglobal.
Default Query:
https://engine.tygron.com/api/session/items/globals/?f=JSON&token=API_TOKEN
Example Response:
  "actualValue" : [ 1.0, 2.0 ],
  "bookValueStakeholderID" : -1,
  "calcTimeMS" : 0,
  "id" : 2,
  "name" : "HELLO",
  "point" : null,
  "previousValue" : [ 1.0, 2.0 ],
  "query" : "",
  "queryTiming" : "AFTER",
  "startValue" : [ 1.0, 2.0 ],
  "version" : 2,
  "visualisationName" : ""
  "actualValue" : [ 3.0, 4.0 ],
  "calcTimeMS" : 0,
  "id" : 3,
  "name" : "HELLO2",
  "point" : null,
  "previousValue" : [ 3.0, 4.0 ],
  "query" : "",
  "startValue" : [ 3.0, 4.0 ],
  "version" : 1,
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/globals/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/globals/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/globals/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/globals/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/globals/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/globals/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/globals-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/globals/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/globals/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/globals/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/globals/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/globals/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/globals/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/globals/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/globals/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/globals/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/globals/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/globals/?f=ZIPSMILE&token=API_TOKEN
Api Model Global
API Model description of Global
Name Type Description
actualValue double[]
bookValueStakeholderID int Stakeholder ID
calcTimeMS long
id int
name String
point Point
previousValue double[]
query String
queryTiming Timing
startValue double[]
version int
visualisationName String
Api Model Point
API Model description of Point
Api Model Timing
API Enumeration description of Timing
Name Description
BEFORE
AFTER
