Api session items areas
Revision as of 14:13, 24 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Area Endpoints.
Edit items with event: editorarea.
Default Query:
https://engine.tygron.com/api/session/items/areas/?f=JSON&token=API_TOKEN
Example Response:
  "attributes" : {
    "ACTIVE" : [ 1.0 ],
    "COLOR" : [ -6642027.0 ]
  "center" : {
    "type" : "Point",
    "coordinates" : [ 658758.7539618125, 6799054.6042297175, 44.792 ]
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "Area",
  "polygons" : {
    "type" : "MultiPolygon",
    "coordinates" : [ [ [ [ 658853.0042034745, 6799058.615645016 ], [ 658851.9842460075, 6799066.578391472 ], [ 658850.2918961977, 6799074.429085737 ], [ 658847.94177127, 6799082.106013204 ], [ 658844.9468643129, 6799089.557203418 ], [ 658841.3331615041, 6799096.724189491 ], [ 658837.1234007488, 6799103.561496871 ], [ 658832.3484406329, 6799110.015530561 ], [ 658827.0440121504, 6799116.042439843 ], [ 658821.2474704315, 6799121.598373932 ], [ 658815.0010430146, 6799126.642730138 ], [ 658808.346957438, 6799131.138153902 ], [ 658801.3388101931, 6799135.053786966 ], [ 658794.0220770903, 6799138.36039521 ], [ 658786.4519787569, 6799141.035240881 ], [ 658778.6821116839, 6799143.058834491 ], [ 658770.7676964987, 6799144.414934827 ], [ 658762.7672021004, 6799145.0970452605 ], [ 658754.7390973885, 6799145.0970452605 ], [ 658746.7386029902, 6799144.414934827 ], [ 658738.8241878048, 6799143.058834491 ], [ 658731.0543207319, 6799141.035240881 ], [ 658723.4842223984, 6799138.36039521 ], [ 658716.1674892956, 6799135.053786966 ], [ 658709.1577179146, 6799131.139777972 ], [ 658702.5068806102, 6799126.642730138 ], [ 658696.2588290572, 6799121.598373932 ], [ 658690.4622873383, 6799116.042439843 ], [ 658685.1578588558, 6799110.015530561 ], [ 658680.3828987399, 6799103.561496871 ], [ 658676.1731379846, 6799096.724189491 ], [ 658672.5594351758, 6799089.555579355 ], [ 658669.5661523548, 6799082.106013204 ], [ 658667.214403291, 6799074.429085737 ], [ 658665.5220534812, 6799066.580015526 ], [ 658664.5020960142, 6799058.615645016 ], [ 658664.1626515706, 6799050.59444046 ], [ 658664.5020960142, 6799042.573243854 ], [ 658665.5220534812, 6799034.61052101 ], [ 658667.214403291, 6799026.76148941 ], [ 658669.5661523548, 6799019.0846144315 ], [ 658672.5594351758, 6799011.635113136 ], [ 658676.1731379846, 6799004.464954313 ], [ 658680.3828987399, 6798997.629354677 ], [ 658685.1578588558, 6798991.173786552 ], [ 658690.4622873383, 6798985.14697024 ], [ 658696.2588290572, 6798979.591129807 ], [ 658702.5068806102, 6798974.548489276 ], [ 658709.1577179146, 6798970.051528442 ], [ 658716.1674892956, 6798966.135975195 ], [ 658723.4842223984, 6798962.829437302 ], [ 658731.0543207319, 6798960.154650514 ], [ 658738.8241878048, 6798958.132726663 ], [ 658746.7386029902, 6798956.775033504 ], [ 658754.7390973885, 6798956.09456297 ], [ 658762.7672021004, 6798956.09456297 ], [ 658770.7676964987, 6798956.775033504 ], [ 658778.6821116839, 6798958.132726663 ], [ 658786.4519787569, 6798960.154650514 ], [ 658794.0220770903, 6798962.829437302 ], [ 658801.3388101931, 6798966.135975195 ], [ 658808.3485815742, 6798970.049904404 ], [ 658815.0010430146, 6798974.548489276 ], [ 658821.2474704315, 6798979.591129807 ], [ 658827.0440121504, 6798985.14697024 ], [ 658832.3484406329, 6798991.173786552 ], [ 658837.1234007488, 6798997.629354677 ], [ 658841.3331615041, 6799004.464954313 ], [ 658844.9468643129, 6799011.633489088 ], [ 658847.94177127, 6799019.0846144315 ], [ 658850.2918961977, 6799026.76148941 ], [ 658851.9842460075, 6799034.61052101 ], [ 658853.0042034745, 6799042.573243854 ], [ 658853.3452720542, 6799050.59444046 ], [ 658853.0042034745, 6799058.615645016 ] ] ] ]
  "relations" : null,
  "sourceIDs" : [ 1000001 ],
  "version" : 3
  "attributes" : {
    "ACTIVE" : [ 1.0 ],
    "COLOR" : [ -1.1156189E7 ],
    "OOPIE" : [ 94.0 ]
  "center" : {
    "type" : "Point",
    "coordinates" : [ 659054.0836208455, 6798899.024563928, 40.502 ]
  "id" : 1,
  "name" : "Area (2)",
  "polygons" : {
    "coordinates" : [ [ [ [ 659143.4549576816, 6798911.089440973 ], [ 659142.3732830432, 6798919.068282583 ], [ 659140.5818609316, 6798926.917209755 ], [ 659138.0936844358, 6798934.572884931 ], [ 659134.929867325, 6798941.976842419 ], [ 659131.1147716406, 6798949.067368267 ], [ 659126.6792559683, 6798955.7859964 ], [ 659121.6590513022, 6798962.080756758 ], [ 659116.0947610447, 6798967.899679161 ], [ 659110.0302368703, 6798973.197289515 ], [ 659103.5174511339, 6798977.929737752 ], [ 659096.6051279185, 6798982.0596699575 ], [ 659089.3501119873, 6798985.552980365 ], [ 659081.8124963758, 6798988.382059442 ], [ 659074.0507499833, 6798990.524169922 ], [ 659066.1282141175, 6798991.961446793 ], [ 659058.1098542222, 6798992.682521388 ], [ 659050.0573874689, 6798992.682521388 ], [ 659042.0374034374, 6798991.961446793 ], [ 659034.1181158439, 6798990.524169922 ], [ 659026.3547453153, 6798988.382059442 ], [ 659018.8155055676, 6798985.552980365 ], [ 659011.5621137725, 6798982.0596699575 ], [ 659004.6497905571, 6798977.929737752 ], [ 658998.1353806846, 6798973.197289515 ], [ 658992.0708565102, 6798967.899679161 ], [ 658986.5081903888, 6798962.080756758 ], [ 658981.4879857227, 6798955.7859964 ], [ 658977.0524700504, 6798949.067368267 ], [ 658973.2373743659, 6798941.976842419 ], [ 658970.071933119, 6798934.572884931 ], [ 658967.5837566232, 6798926.917209755 ], [ 658965.7923345118, 6798919.066658555 ], [ 658964.7122840093, 6798911.089440973 ], [ 658964.3501016604, 6798903.045646268 ], [ 658964.7122840093, 6798895.003483584 ], [ 658965.7923345118, 6798887.024665694 ], [ 658967.5837566232, 6798879.175777204 ], [ 658970.071933119, 6798871.518530398 ], [ 658973.2373743659, 6798864.114637359 ], [ 658977.0524700504, 6798857.025809942 ], [ 658981.4879857227, 6798850.30563976 ], [ 658986.5081903888, 6798844.010966325 ], [ 658992.0708565102, 6798838.192132981 ], [ 658998.1353806846, 6798832.8946109805 ], [ 659004.6497905571, 6798828.162247533 ], [ 659011.5621137725, 6798824.034017855 ], [ 659018.8155055676, 6798820.540777152 ], [ 659026.3547453153, 6798817.71175673 ], [ 659034.1181158439, 6798815.569691985 ], [ 659042.0374034374, 6798814.132446433 ], [ 659050.0573874689, 6798813.409763738 ], [ 659058.1098542222, 6798813.409763738 ], [ 659066.1282141175, 6798814.132446433 ], [ 659074.0507499833, 6798815.569691985 ], [ 659081.8124963758, 6798817.71175673 ], [ 659089.3501119873, 6798820.540777152 ], [ 659096.6051279185, 6798824.034017855 ], [ 659103.5174511339, 6798828.162247533 ], [ 659110.0302368703, 6798832.8946109805 ], [ 659116.0947610447, 6798838.192132981 ], [ 659121.6590513022, 6798844.010966325 ], [ 659126.6792559683, 6798850.30563976 ], [ 659131.1147716406, 6798857.025809942 ], [ 659134.929867325, 6798864.113013343 ], [ 659138.0936844358, 6798871.518530398 ], [ 659140.5818609316, 6798879.175777204 ], [ 659142.3732830432, 6798887.024665694 ], [ 659143.4549576816, 6798895.003483584 ], [ 659143.8155158944, 6798903.045646268 ], [ 659143.4549576816, 6798911.089440973 ] ] ] ]
  "relations" : null,
  "version" : 4
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/areas/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/areas/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/areas/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/areas/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/areas/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/areas/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/areas-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/areas/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/areas/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/areas/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/areas/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/areas/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/areas/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/areas/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/areas/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/areas/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/areas/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/areas/?f=ZIPSMILE&token=API_TOKEN
Api Model Area
API Model description of Area
Name Type Description
attributes Map<String,double[]>
center Point
id int
maquetteOverride Map<String,double[]>
name String
polygons MultiPolygon
relations Map<Relation,int>
sourceIDs int[] Source ID
version int
Api Model EmptyMultiPolygon
API Model description of EmptyMultiPolygon
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
Api Model Point
API Model description of Point
Api Model Relation
API Enumeration description of Relation
Name Description
OWNER
CONSTRUCTOR
DEMOLISHER
PERMITTER
SENDER
RECEIVER
NETOWNER
BORDER_A
BORDER_B
BUILDING
WEATHER
PARENT
RESULT_PARENT
