Api session items netloads
Revision as of 13:28, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Net Loads Endpoints.
Edit items with event: editornetload.
Default Query:
https://engine.tygron.com/api/session/items/netloads/?f=JSON&token=API_TOKEN
Example Response:
  "addressIDs" : [ ],
  "attributes" : {
    "ROOT_LOAD" : [ 1.0 ]
  "buildingID" : -1,
  "clusterID" : -1,
  "connectionState" : "NOTHING",
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "NetLoad 0",
  "netType" : "ELECTRICITY",
  "nodeID" : 0,
  "point" : null,
  "sourceIDs" : [ ],
  "version" : 156
  "addressIDs" : [ 90 ],
  "attributes" : {
    "TYPE" : [ 5.0 ]
  "buildingID" : 444,
  "clusterID" : 0,
  "id" : 1,
  "name" : "NetLoad 1",
  "nodeID" : 2,
  "point" : null,
  "sourceIDs" : [ 12 ],
  "version" : 157
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netloads/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/netloads/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/netloads/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/netloads/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/net_loads-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/netloads/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/netloads/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netloads/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/netloads/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/netloads/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/netloads/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/netloads/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netloads/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netloads/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPSMILE&token=API_TOKEN
Api Model NetLoad
API Model description of NetLoad
Name Type Description
addressIDs int[] Address ID
attributes Map<String,double[]>
buildingID int Building ID
clusterID int Net Cluster ID
connectionState TimeState
id int
maquetteOverride Map<String,double[]>
name String
netType NetType
nodeID int Net Node ID
point Point
sourceIDs int[] Source ID
version int
