Api session items scenarios
Revision as of 12:43, 20 April 2026 by Frank@tygron.nl (talk | contribs) (Replaced content with "Api session items Scenario Endpoints. Edit items with event: editorscenario. Default Query: <syntaxhighlight lang="text" copy>https://engine.tygron.com/api/session/items/scenarios/?f=JSON&token=API_TOKEN</syntaxhighlight> Example Response: <syntaxhighlight lang="text" copy>[ { "attributes" : null, "description" : "", "events" : [ ], "id" : 0, "limitNeighborhoodIDs" : [ ], "limitType" : "DEFAULT", "maquetteOver...")
Default Query:
Example Response:
  "description" : "",
  "events" : [ ],
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "Scenario",
  "restartTestrun" : true,
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/scenarios/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/scenarios/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/scenarios/size/?token=API_TOKEN
Scenarios (GeoJSON):
https://engine.tygron.com/web/scenarios.geojson?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/scenarios/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/scenarios/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/scenarios/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/scenarios/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/scenarios/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/scenarios/?f=ZIPSMILE&token=API_TOKEN
Api Model LimitType
API Enumeration description of LimitType
Name Description
DEFAULT
NEIGHBORHOODS
MEASURE_NEIGHBORHOODS
Api Model Scenario
API Model description of Scenario
Name Type Description
attributes Map<String,double[]>
description String
events CodedEvent[]
id int
limitNeighborhoodIDs int[] Neighborhood ID
limitType LimitType
maquetteOverride Map<String,double[]>
name String
restartTestrun boolean
version int
Api Model ScenarioAttribute
API Enumeration description of ScenarioAttribute
Name Description
LIMIT_MARGIN
INDICATORS
