Api session items parametricdesigns
Api session items Parametric Designs Endpoints.
Edit items with event: editorparametric.
Default Query:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=JSON&token=API_TOKENExample Response:
[ ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/parametricdesigns/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/parametricdesigns/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/parametricdesigns/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPSMILE&token=API_TOKENApi Model Alignment
API Enumeration description of Alignment
| Name | Description |
| ROAD | |
| SPACED |
Api Model DesignAttribute
API Enumeration description of DesignAttribute
| BACKYARD_DISTANCE_M | |
| WATER_WIDTH_M | |
| KEEP_EXISTING_ROADS | |
| ROAD_WIDTH_M | |
| ROAD_DISTANCE_Y_M | |
| ROAD_SEARCH_DISTANCE_M | |
| SIDEWALK_WIDTH_M | |
| PARKING_WIDTH_M | |
| PARKING_LENGTH_M | |
| FRACTION_BUILDINGS | |
| FRACTION_ROADS | |
| FRACTION_WATER | |
| FRACTION_PUBLIC_GREEN | |
| FRACTION_GARDENS | |
| FRACTION_PARKING | |
| FRACTION_REMAINDER |
Api Model Example
API Enumeration description of Example
| CITY_NEIGHBORHOOD | |
| URBAN_NEIGHBORHOOD | |
| SUBURBAN_NEIGHBORHOOD | |
| WINDMILL_AREA |
Api Model FunctionType
API Enumeration description of FunctionType
| ROAD | |
| WATER | |
| PARKING | |
| SIDEWALK | |
| BUILDING | |
| GARDEN | |
| PUBLIC_GREEN | |
| REMAINDER |
Api Model PDResult
API Model description of PDResult
| Name | Type | Description |
| areaExisting | Map<FunctionType,double> | |
| bandMPs | Map<FunctionType,java.util.Map<java.lang.Integer, java.util.List<org.locationtech.jts.geom.MultiPolygon>>> | |
| detailMPs | Map<FunctionType,java.util.Map<java.lang.Integer, java.util.List<org.locationtech.jts.geom.MultiPolygon>>> |
Api Model ParametricDesign
API Model description of ParametricDesign
| alignment | Alignment | |
| attributes | Map<String,double[]> | |
| center | Point | |
| gardenID | int | Function ID |
| id | int | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| parkingID | int | Function ID |
| plotDesigns | PlotDesign[] | |
| polygons | MultiPolygon | |
| publicGreenID | int | Function ID |
| roadID | int | Function ID |
| sidewalkID | int | Function ID |
| sourceIDs | int[] | Source ID |
| version | int | |
| waterID | int | Terrain Type ID |
